In Reply to: OT For Bruce posted by 8NChris on April 16, 2023 at 10:23:11:
This money bucket in the asphalt also has an upgraded cooling fan to go with it.
I ran it WOT over Mt Hood a few years ago and it didn't make it for several reasons.
The next trip over Mt Hood should be a bit cooler at WOT and 11,245 ft elevation.
Then again, last trip I figured something was not right and I pushed it up this side rather than breaking down on the other side. I got it turned around, cooled down and made it home. Along with everything else came a $600 radiator.
The exhaust system came from Diamond Eye in Ontario, Ore. they wanted to use my truck for a mock up to sell other systems and it does have the 3" down pipe that currently runs into a 4" pipe. The 4" is going to get pulled out and reroute a 3" pipe inside the frame rail a bit to install a PTO pump on the BW1356 Transfer case possibly.
Paint job will get a white pearlescent at some time.
