In Reply to: Re: 1952 8n electrical problem posted by Bruce(VA) on April 08, 2023 at 14:39:09:
Gentlemen: I found the problem - self inflicted. I recently had the starter off to clean and service it. It was running great till I did that. So, I just retraced the wires and found that I had also connected the ammeter wire together with the interlock switch terminal on the solenoid. So, apparenly was also grounding the iginition when I pushed the interlock. I have great spark again and will start her up. Hope I don;t get kicked off the site for this one... Thank you for your time and advice, John.
