In Reply to: Re: 1952 8n electrical problem posted by John Bear on April 08, 2023 at 13:52:20:
The voltage regulator is not in the ignition circuit.
When you press the neutral safety switch, it grounds the solenoid. When the solenoid is grounded, the bendix engages the ring gear.
Put the tractor in neutral. Turn the key on. Ground the small wire on the BACK of the solenoid to the block w/ a screw driver. What happens?
