53 Jubilee
Posted by Craig Tucker on March 06, 2023 at 12:40:34 [URL] [DELETE] :
on the 53 Jubilee center housing behind the acorn nut is the back pressure relief valve . if i take a screw driver and push in on this valve the lift works correctly NO one has this part that i can find. if i put a compression spring in between the acorn nut and valve to put a little pressure on the valve will this cause any problems down the road
