In Reply to: Re: Kromer posted by John in Mich on February 21, 2023 at 17:54:59:
Yes when adjusting the carb it may be necessary to adjust the governor. Here is the 2nd page from the 8N Owner's Manual for Fuel. Get carb tuned right first. When adjusting the carb, it must be done after engine gets warmed up and under load. Only make short 1/8" - 1/4" turns of Air Idle and Main screw at a time and wait until engine speed catches up. Use a long neck screwdriver to make adjustments with as engine gets hot so keep your hands clear to avoid getting burned.
8n governor adjustment -
