Re: 8N Timing
Posted by Bruce(VA) on February 03, 2023 at 16:16:20 [URL] [DELETE] :
In Reply to: 8N Timing posted by Jack Duncan on February 01, 2023 at 16:46:35:
The reason the instructions say set it in the middle is because you cannot set the timing w/ EI on a front distributor. Unless you want to take it off, adjust it a few degrees and put it back on and see if it helps.
Are you using suppression plug wires? Copper wires will burn up the module.
