In Reply to: Re: 8N oil pan removal posted by littleguns on January 12, 2023 at 14:17:43:
I finally had the time and decent temp to prime the pump. I squirted 90W in until it was running out the front. I took the line off at the t so I could see it. Started up and in a few seconds I had a mess of oil running down my engine. Hooked everything back up and had good oil pressure again. I guess the real test will be if I start it after work tomorrow, will I still have pressure. I will keep you all posted. Thanks for the help!
