In Reply to: Re: 8N oil pan removal posted by Jim Menke on January 11, 2023 at 15:51:10:
You may just need to prime your system. It's not that uncommon for folks to encounter this. Before you drain your oil or drop the pan, remove the large bolt on the front cover of the engine (watch out for the spring) and squirt some oil in the opening and reinstall the pressure relief valve and bolt. See if that gets you oil pressure. The bolt in question will be here and look like this:
