I removed the right trumpet from mu Jubilee to replace the lower lift link pin. I noticed that the Differential Bearing that runs on the race in the trumpet was worn and needs replacing. I also noticed that that part that the bearing on on is bolted on. How do I replace the bearing? Do I unbolt the part it is on? Do I have to cut the bearing off or just what is the best method of replacing the beating? Image 9727
