In Reply to: Re: 226 H Series: Funk Cast Iron Oil Pan With A Hydraulic Pump? posted by Ed Gooding (VA) on December 13, 2022 at 14:51:00:
Talked to a man with 4 or 5 Funks apart in his shop. He is pretty sure all of his have two bolt holes in them. Mine is as cast on the face so I'll need to have it cut true then tap the holes. Assuming it is thick enough. Looks kind thin to support any rotating mass. I'll know better when it is torn down.
