In Reply to: Re: Jubilee Running Rough posted by John in Mich on December 04, 2022 at 18:54:16:
Probably wasn't running well b/4 tuneup. I remember adjusting main needle and nothing happening. Wasn't running on #1 cylinder then but I was getting a jolt when removing #1 plug wire off plug while tractor running. Figured it was time to replace wires, cap, etc. The old plug was wet then. I assumed not enough spark on that cylinder cause the wet plug.
I have the plug wires at 1,2,4,3 corresponding to the #1 mark on distributor cap. Will check things out more when I have time. Tractor is at farm 110 miles away.
Thanks for the tips in advance.
Tyler
