In Reply to: No start 8N posted by Mike Maiman on November 29, 2022 at 15:07:27:
I fought a similar situation on my 860 for longer than I care to admit. Finally a member here wrote: If it does not fire on starter fluid, you have an ignition problem.
One of my problems was the engine had not been assembled correctly! Timing marks meant nothing. Resorted to finding compression on #1 and setting distributor on that. Final timing by ear as we did before we could afford timing lights.
Good Luck,
Jack - Iowa
