In Reply to: No start 8N posted by Mike Maiman on November 29, 2022 at 15:07:27:
Sorry, ignore my previous post regarding compression. Didn't see that you already checked that.
Are you sure the distributor and plug wires are properly installed? Is the spark which is present at the plugs of sufficient intensity. The spark should be able to jump a 1/4 inch gap if the ignition is good.
