Re: Headlights not working
Posted by K.LaRue-VA on November 22, 2022 at 20:29:37 [URL] [DELETE] :
In Reply to: Headlights not working posted by Bob Nelson on November 15, 2022 at 13:26:54:
I avoided the issue by pulling two wires into each light housing so I could run ground wires back to where the battery ground strap is bolted. Seems like I had to use fixture wire that had thinner high temp insulation to fit both of them through the hole in the mounting bolt.
