Re: NAA Cranks, dies out
Posted by Ed Gooding (VA) on September 13, 2022 at 14:59:55 [URL] [DELETE] :
In Reply to: NAA Cranks, dies out posted by Lucy on September 12, 2022 at 13:35:52:
>> I know we're getting fuel - I've turned the bulb assembly to all the way on, to the point I can see fresh fuel being injected into the bulb. It is now full. There is gasoline in the tank. Likely around 1/4th full. <<
Have you confirmed that the fuel is getting from the sediment bowl assembly to the carb? If not, get a pint jar like a Mason jar. Open the sediment bowl valve. Remove the bolt at the bottom of the carb's fuel bowl. You should be able to fill the jar in about 2 minutes. If you cannot, then you have a blockage of some type. Remove the fuel line from the carb and unscrew the fuel inlet fitting. There should be a mesh screen filter there. If it's clogged, gently clean it and see if she will run. If not, then a carb cleaning/overhaul may be your next step.
Let us know what you find and we will try to help you get her running.
