Re: NAA or Jubilee
Posted by Jacl - Iowa on August 26, 2022 at 07:41:36 [URL] [DELETE] :
In Reply to: NAA or Jubilee posted by Ron on August 25, 2022 at 21:42:34:
I'd start with my multimeter and check the battery cables. If you don't have a multimeter, take a jumper cable and jump around one at a time.
If that does not cure it, check the various ground points in the system. Did you clean the mounting surface when you had the starter off?
May be the solenoid it's self but don't spend any more money until you have done some trouble shooting.
Good Luck
