Re: Ford 2N Ignition Coil Circuit
Posted by Tim Daley(MI) on August 12, 2022 at 02:38:57 [URL] [DELETE] :
In Reply to: Re: Ford 2N Ignition Coil Circuit posted by Phillip G. on August 11, 2022 at 19:31:32:
Hey Phil, no problem, we all get that way. At this point I want to propose that I am willing to rebuild your front mount distributor for you correctly, you pay for parts and shipping. Be sure you have the OEM Ballast Resistor in the circuit and discard any other external resistor with using the 12V coil. It will be your responsibility to get it mounted correctly on the engine and wired correctly with a 12V coil. Get a good, fully tested and charged battery too. Use your 12V ALT and be sure it has belt tensioner device attached. Put your VOM and OHM meter aside for now and forget about trying to measure anything except when testing the distributor, coil voltage, and doing a spark test. Email me if interested...
