Re: Ford 2N Ignition Coil Circuit
Posted by Phillip G. on August 09, 2022 at 19:10:52 [URL] [DELETE] :
In Reply to: Re: Ford 2N Ignition Coil Circuit posted by JMOR on August 09, 2022 at 17:04:07:
By gosh, I believe that was it. I did use the dash resistor and I think a 2.5 ohm ceramic resistor because I figured out I didn't won't but 3.5 to 4 amps at the coil. I had this in a manual when I did it some 10 years ago. The coil has gone bad I'm fairly certain. It's showing 9 ohms of resistance with it un-hooked. I'll do some further testing because the timing advance flyweights have came apart also. I may just do some research on those aftermarket distributors & a 12V coil. I believe you have given me the same specs I figured out when I did the 12V conversion, and I appreciate your help greatly.
