Low Ratio
Posted by Kirk-NJ on August 09, 2022 at 02:57:34 [URL] [DELETE] :
I have seen a couple of these over the years stamped on the transmission But have not had an opportunity to open one up to check out the differences. Can anyone shed some light on this. The couple I have seen have been 9n's so I assume it may have been an early special order? I would also assume that it had to do with trans gearing cause if it had to do with pinion gear I would think it would have been stamped on the rear housing lip not trans lip
