Re: 3 point hitch pin loose and leaking
Posted by Daniel Romans on August 05, 2022 at 15:41:01 [URL] [DELETE] :
In Reply to: 3 point hitch pin loose and leaking posted by Daniel Romans on August 02, 2022 at 18:24:04:
Thanks for all the helpful replies. I have yet to remove my axle housings and want to gather as much info as possible before I tackle the job. I was hoping there was some aftermarket upgrade that improved on the pin design such as a tapered pin like the 8n's use. A local mechanic suggested I use JB Weld upon assembly and it should work fine. Ford's part number for the loose pin is 563, just to be sure we're all on the same page. So, has anybody used JB Weld to take up the slop and seal the pin from leaking oil? Thanks all.
