Stuck leveling arm
Posted by Zeke on July 21, 2022 at 22:46:04 [URL] [DELETE] :
My 47 2N has a crank adjusted leveler on the 3pt. It was generously over lubed by Moses just about the time they got past the Red Sea. Ok not quite. But it is stuck. Is there a preferred way to remove the fossilized lube from the adjuster? And what is the right name for the part?
Thanks
