Re: 8N hesitation when going wide open throttle.
Posted by John in Mich on July 21, 2022 at 20:41:35 [URL] [DELETE] :
In Reply to: 8N hesitation when going wide open throttle. posted by Robert Betz on July 19, 2022 at 22:48:47:
I'm with Dean on the carb adjustment. If adjustment is too lean, engine will stumble. If adjustment is too rich with today's gasoline, fowled plugs.
My test is with a warm engine:
1. slap gas lever to wide open throttle and back to idle. If it stumbles, open main jet 1/8 turn and try again. Repeat until no stumble.
2. after eliminating the stumble, close the main jet 1/8 turn and re-test to wide open throttle. If it stumbles, open the 1/8 turn. If no stumble, close another 1/8 turn. Re-test.
