Re: Oil leak part?
Posted by Mike Maiman on July 11, 2022 at 13:11:51 [URL] [DELETE] :
In Reply to: Oil leak part? posted by Travis Webb on July 10, 2022 at 15:34:20:
Sounds like you have a rear main seal leak. The hole with the cotter pin allows the oil to drain out. Otherwise it would fill the bell housing and soak the clutch. Keep an eye on the crankcase oil level.
