In Reply to: Worklight bulb retaining clips posted by Jim Sutherland on May 15, 2022 at 12:14:54:
Yes, I went thru this recently. The edge of the seal beam is thicker than the thickness of the lens and reflector the clips were made to retain which makes them way too tight for holding in a seal beam. So I used 2 pairs of pliers and widened the clips some and it all went together perfectly. Until then, good grief I was turning the air blue.
