Re: Fan bearing?
Posted by Bruce(VA) on June 11, 2022 at 15:04:39 [URL] [DELETE] :
In Reply to: Fan bearing? posted by Kevin Fisher on June 11, 2022 at 14:59:37:
No.
I can assure you it's not a fan bearing because it does not have a bearing.
But the water pump does.
And you are lucky that it seized because they usually just fall apart and launch the fan into the radiator.
Replace the water pump. Best to have it rebuilt. if you don't have a rebuild shop nearby, get a pump from Just8N's
