Re: 1952 8N with 12 volt conversion….
Posted by Will on June 06, 2022 at 06:29:17 [URL] [DELETE] :
In Reply to: 1952 8N with 12 volt conversion…. posted by Dead Eye Dave on June 06, 2022 at 04:24:27:
Do you have a multimeter? It could be the battery has failed, or it could be its no longer charging. You would need to test it to be sure of anything. I'd run the battery to the store and have it tested. I'd assume it ran just fine so the alternators probably charging so Id start with the battery.
Once you have a good charged battery in it, if it fires right up I'd check charging voltage just to cover the bases.
