Re: Transmission leak
Posted by Jack - Iowa on June 04, 2022 at 06:49:52 [URL] [DELETE] :
In Reply to: Re: Transmission leak posted by David on May 31, 2022 at 14:33:41:
Splitting is not as bad as it sounds. I split my 860 while it was setting on gravel. That certainly added to the difficulty. I got some long bolts and cut the heads off to make guide pins. Without those I might still be fighting it! As memory is crap, I can't be sure, but think I was able to use some 4 inch bolts. Longer is better if you can get them in. Not sure there is a limit on the length of the bolt on the bottom.
Good Luck,
Jack - Iowa
