Re: 53 jub no power to coil
Posted by mhb@ufe on May 31, 2022 at 06:40:49 [URL] [DELETE] :
In Reply to: 53 jub no power to coil posted by jim mitchell on May 30, 2022 at 19:23:54:
The first thing I would do is disconnect the wire going to the coil and see if there is power to the wire. A short in the distributor will show as a no power problem with every thing hooked up. If there is power to the wire you need to find the short, if no power to the wire you can trace back and find out where the power loss is.
Mark
