Sticking clutch problem not solved…..52 Ford 8N
Posted by Dead Eye Dave on May 30, 2022 at 04:25:10 [URL] [DELETE] :
Problem: while running along and I push the clutch in the tractor continues along for ten feet before the clutch disengages. So, I checked the archives here. Next I opened the hatch used to do the timing and, with tractor running I poured a gallon of varsol in. I did this with clutch engaged and with clutch blocked. I caught the varsol as it dripped out the weeper holes. It was black! I then sprayed in a full can of brake cleaner. After this I blocked the clutch as usual and left it to dry for a day. This made zero difference!!! Now, tell me…..is this definitely the clutch sticking to the flywheel or could it be something else. I am not looking forward to breaking the tractor. Dave
