Re: Coil?
Posted by Bruce(VA) on May 27, 2022 at 20:17:35 [URL] [DELETE] :
In Reply to: Coil? posted by 2NTony on May 27, 2022 at 15:25:51:
The tab is secondary voltage. You won't see 20k voltage and if you did, you wouldn't have a meter left.
You should see about 1.5 ohms on the primary and 8k or so on the secondary.
Your problem is likely in the distributor.
