Re: donnahoo
Posted by continentalsey on May 13, 2022 at 00:18:23 [URL] [DELETE] :
In Reply to: donnahoo posted by frank on May 03, 2022 at 17:43:24:
The nature of the sounds of a working tractor. Usually, when the tractor is working, a monotonous dull sound comes from the mechanisms. When malfunctions occur, a wide variety of sounds arise, which, with sufficient attention of the tractor driver, can be easily and timely detected by him. In case of extraneous sounds, the tractor should be stopped immediately and find out the cause of their occurrence. Extraneous knocks in the engine are particularly dangerous. If they are detected, the engine must be turned off and start working only after the detection and troubleshooting. You can follow the new models with https://www.heming-engineering.co.uk/tractors-and-machinery/siromer-small-tractors.
