In Reply to: Re: donnahoo posted by Bruce(OR) on May 04, 2022 at 00:07:10:
Thanks, Bruce.
I have read and seen pictures of doing this, and that will be my next step.
Since it means a trip to the hardware store, I will try increasing the float adjustment to something between 1/4 inch and 1/2 inch.
See my follow up to the other reply to my post.
Thanks, and if float adjustment does not cure my ills, I will definitely get some clear tubing and a barb fiting to connect to the drain hole in the float bowl, to see where the level is when the tractor stalls.
Funny. Man is pretty inventive. This is a story about using clear hose to check for level.
I was building a beach cabin in the country of Panama, on a remote island with no roads, stores, etc.
We went to 2 islands over and bought about 75 feet of clear tubing.
We filled the tubing with water, and used that to level the footings on the foundation.
So, thanks for the tip and I return your help with a story.
Hopefully, I can relate a good ending to this, what should have been a simple fix but has turned into a nightmare.
Thank you, sir.
Frank
