Re: donnahoo
Posted by Bruce(OR) on May 04, 2022 at 00:07:10 [URL] [DELETE] :
In Reply to: Re: donnahoo posted by HCooke on May 03, 2022 at 19:02:30:
Remove the drain plug on the bottom of the new carb.
Install a barb with clear open ended hose on bottom.
Hold the hose up towards the gas tank.
Turn on the gas flow.
Level inside the hose will show you the level inside the carb.
It should be very close to the center line of the carb.
Too low needs adjustment.
Too high and the gas should be flowing out the carb throat.
