Re: 9N Question (looking for mechanic)
Posted by Steve Dabrowski on April 30, 2022 at 16:53:53 [URL] [DELETE] :
In Reply to: Re: 9N Question (looking for mechanic) posted by Bruce(OR) on April 27, 2022 at 18:58:38:
Just be careful that the machine shop does not set it up using the carb flange as a right angle position index point. I had a great manifold on my 8N done by the machine shop and they faced it 90 from the carb flange and when I tried to install it the carb fell too close to the block. The face of the engine block is about a 2 from perpendicular, so beware.
I had a thin plate made up to insert between the manifold and the block that was cut with a 2 bevel to correct the angle, that and two manifold gaskets fixed the problem.
