In Reply to: Re: Dearborn 19-3 Snow Blade posted by Thomas on April 13, 2022 at 04:58:33:
There were two versions of the 19-80 plow frame. One is cable operated and one is hydraulic operated. Do you know which version you found? Also, make sure the blade is the snow blade if you buy it. The snow blade has trip springs behind the blade, the dirt blade does not. You could always buy it if the price is right and it has the snow blade as the same blade mounts to the 19-80 and the 19-3 frames and keep searching for a 19-3 frame.
