Re: Noob 9N question
Posted by Mr_Huns on April 13, 2022 at 07:18:37 [URL] [DELETE] :
In Reply to: Re: Noob 9N question posted by ken b nc on April 13, 2022 at 06:59:36:
Thank you for the reply.
The link is just laying there. I disconnected it to remove the lift arm. The handle points towards the implement when installed. I keep thinking the lift arm is too low. I don't really want to open up the functional hydraulic system only to find out the lift shaft only gets installed one way. The IT shop manual has pictures, but not really good.
Does anyone know if the center keyway and the lift arm keyways are on the same plane? If they're offset a tooth or 2, then the shaft could be 180 degrees out?
