In Reply to: LEAKS posted by larry rice on April 10, 2022 at 09:22:55:
NO! The trans, hydraulic pump and diffy all use the same oil. Where are the leaks? There is a drain hole in front of the transmission under the clutch to drain engine or trans oil that leaks out of seals. There should be a big old cotter key hanging there to keep the hole free of dirt.
