In Reply to: Hydraulic oil level posted by Jim on April 06, 2022 at 19:14:58:
You did n ot say what tractor that you are working on.
For the 9N-8N, the book says, "with all cylinders extended" or arms up. On an N there may be a max of a quart in the 3-point lift cylinder. Many folks just pull the bottom bolt of the right inspection cover and only fill to there. That is about the same as the "full" mark on the dipstick.
