In Reply to: Re: Ford 8N stalling and back firing posted by Bruce(VA) on March 05, 2022 at 16:43:28:
12 volt with front distributor. After I posted the first message I went back to tinker a bit more. I then discovered that gas was dripping from the carb. Turns out the problem was a frozen carb not wet ignition. Running fine again.
