Re: Shift lever spring seat UPDATE
Posted by Steve Dabrowski on January 19, 2022 at 17:36:11 [URL] [DELETE] :
In Reply to: Re: Shift lever spring seat UPDATE posted by Chy NY on January 19, 2022 at 08:35:50:
Perhaps the pin that the shift lever pivots around has sheared off. It goes through the lever at the top of the pivot ball section and rides in a slot on one side of the shift lever housing. Pull up the boot and you should be able to see if it is in place and working.
