Re: Engine Oil Leak from Proofmeter Cable Port on Hydraulic Pump
Posted by mhb@ufe on December 25, 2021 at 10:08:49 [URL] [DELETE] :
In Reply to: Engine Oil Leak from Proofmeter Cable Port on Hydraulic Pump posted by John O in MI on December 23, 2021 at 19:56:25:
I would agree with TOH as oil leaking by the seal would be more of a spray than splash oil from the gears and it would mix with the engine oil off the gears. That could explain the color of the oil. It is also common for the pump shaft to have a groove worn into it where the seal rides.
Mark
