Engine Oil Leak from Proofmeter Cable Port on Hydraulic Pump
Posted by John O in MI on December 23, 2021 at 19:56:25 [URL] [DELETE] :
Hey Gang,
My 800 is leaking engine oil from the proofmeter cable connection on the hydraulic pump. Not just a few drips, more like a small stream coming down the bellhousing that leaves a puddle on the ground after parked. I can't figure out why the oil would leak from this spot. The cam gear would obviously be slinging some oil around in the front portion of the hydraulic pump, but it should be able to drain back to the sump freely.
Any thoughts on what would cause this?
Thanks,
John
