Re: question801
Posted by Mike A on December 12, 2021 at 15:23:54 [URL] [DELETE] :
In Reply to: Re: question801 posted by Jim on December 11, 2021 at 22:02:55:
Recently purchased a 1958 801 power master Ford tractor. I have discovered that it is leaking oil out of a port in the axle housing that holds a hitch pin for the left side lift arm. The hitch pin is bent and needs to be replaced. The axle housing will have to be removed, and the oil drained from the case. I have a good friend who has been a heavy equipment mechanic for many years who is helping me. Is there anything that you might know of that would trip me up, or I should watch for? Thanks
Mike
