Re: Throw out bearing hub springs
Posted by Mike Maiman on December 05, 2021 at 22:04:13 [URL] [DELETE] :
In Reply to: Re: Throw out bearing hub springs posted by mhb@ufe on December 04, 2021 at 19:38:01:
Yes,the springs pull the hub all the way back with good tension. I'll install a new clutch once the engine is rebuilt and take your advice regarding the pedal adjusting rod. Thank you for your help.
Mike
