Re: 8N charging issues
Posted by scott on December 01, 2021 at 20:03:22 [URL] [DELETE] :
In Reply to: Re: 8N charging issues posted by JMOR on December 01, 2021 at 15:52:03:
I jumper field and ground terminals on the generator and the voltage jumped to around 9 volts and the amps on the amp meter went to 30 amps. new battery, in effect three different VRs, original two new VRs and new wiring harness still no output on the amp meter. Would seem to be the voltage reg but I have tried two different VRs plus the one that was on the tractor when I got it all 6 volt, positive ground, "A" circuit VRs
