Re: jubilee has no lift
Posted by Carl on November 21, 2021 at 09:21:48 [URL] [DELETE] :
In Reply to: jubilee has no lift posted by Doug on November 19, 2021 at 07:19:33:
Do you have the PTO engaged? Milky oil signifies that water has contaminated the system. Simply draining it and putting fresh oil in isn't the solution. You need to investigate why that happened. If water got in and froze then you tried to operate the tractor like that, you could have cracked and/or damaged the pump. Sometimes all you need is to replace the safety relief valve but a good inspection is recommended.
