Re: 8N won't crank
Posted by HCooke on November 19, 2021 at 08:23:46 [URL] [DELETE] :
In Reply to: Re: 8N won't crank posted by Mike on November 19, 2021 at 06:22:21:
Remove the brass elbow on the carb. It should have a filter. Check to make sure that filter is clear. If not that may be your problem. If that filter is clear, check to see if the float and needle valve are working properly. Sometime the needle sticks and you can free if with a tap on the side of the carb with a wooden object such as the end of a screw driver. If that does no work then you will have to service the carb.
