Re: 8N won't crank
Posted by Mike on November 19, 2021 at 06:22:21 [URL] [DELETE] :
In Reply to: Re: 8N won't crank posted by Bruce9OR) on November 19, 2021 at 01:56:36:
Will not start, engine turns over when key is turned. Gas is flowing to the carb, but does not seem to be getting into the carb. I loosened the drain screw, but no gas came out, removed the carb and no gas ran out when turned upside down. Are there adjustments on the carb that I can do, I'm not a mechanic, just an old man trying to get his tractor running again.
