8N won't crank
Posted by Mike on November 18, 2021 at 20:21:16 [URL] [DELETE] :
Parked tractor last fall, won't crank now. Have put on new battery, key switch, coil,points & condenser, plugs, and carb. Motor turns over good, Have spark on plugs. Opened drain on carb and no gas drained out, took gas line loose from carb and have gas there. Any ideas on the issue and how to repair.
