Re: Hand Cranking 1949 8N
Posted by Pops on October 25, 2021 at 11:29:23 [URL] [DELETE] :
In Reply to: Hand Cranking 1949 8N posted by Dan Brennan on October 22, 2021 at 18:24:53:
Dan,
Some aftermarket hand cranks have the two pins set too far back on the crank, preventing them from engaging the pulley nut. In which case, grind off the end of the crank to allow the pins to engage. Of course, check that your tractor has the correct pulley nut first.
